1 - 4 of 4 Posts
Administrator
Is it the hose or the nipple on the radiator that broke?
If it is just the hose you can buy them from parts suppliesrs such as brittish Atlantic.
Temporary you can use rubber
If it is the nipple, unfortunately you are probably in for a new radiator. There are a few threads here where folks have tried to install a new nipple but the results are pretty mixed. If it is just the line, no problem. I put a two inch rubber hose piece with clamps over my plastic line break and it has worked for several years.
roverparts.com, rovahfarm.com, roversnorth.com
This applies to any part needing replacement. Google works as well for Land Rover as anything else. There are much more important questions you should be asking. Read the sticky by DiscoMike on this forum as well as the LandRoverForums where you have also visited. Read the thread in its entirety and continue doing searches on "front driveshaft failure," "temperature gauge," "180 degree thermostat," "oil pump"
There are many things you should know about the 2003
1 - 4 of 4 Posts
