1 - 4 of 4 Posts
I noticed a hose in my 03 disco has cracked. I put a temporary duct tape patch on it, and haven't been driving it. Does anyone know what it is, where I can get another, and if there are other repercussions of running the engine while the hose is cracked? I've highlighted where the hose attaches to other parts. I'm currently going the the RAVE manual.
Thank you!
Administrator
Looks like a secondary air injection hose? I would look at that system in rave in more detail and replace sooner than later to avoid catalyst damage.
It is the pipe from the secondary air injection pump and air rail. Many times this hose can break due to one of the SAI valves sticking causing exhaust to feed back up through the air rail. I would check those valves to make sure they will not cause the new pipe to fail. Rovers North sells the pipe. Part# WAH100150. They are about $120.
1 - 4 of 4 Posts
