When I go to put my crank into the block with all the bearings layed out, the center thrust bearing is just too tight of a squeeze. If i put some pressure downward for it to slide in, it will just scuff the sides of the bearing, lightly. I almost just need to buff off the littlest amount to get it in. I tried the freezer, but I need like a DEEEP freeze. The freezer defiantly helped.
