1 - 3 of 3 Posts
I have a 2003 Disco with 305,000 miles and recently started knocking after she warmed up.
So I took the cylinder heads off, as I was getting a water leak on the backside and needed to replace the gasket.Inspected the rocker, lifters etc. and all seemed in good working order. So removed the oil pan and found a camshaft bearing split in two and folded over. So I have removed the camshaft, without removing the engine from the truck and found that the 4th bearing is gone. Not a mark the camshaft or lifters. Have ordered a new camshaft, bearings and lifters.
I need to install the new camshaft bearings. Does anyone have any advice or tricks to install them. I assume the crankshaft has to come out. Also the oil conduit to the 4th bearing may be clogged and how might I check for that?
Any help is greatly appreciated.
Mark
Wow, I thought I was the only one who had experienced this!
With cam bearings, it is often necessary to size the bearings to the camshaft. Be prepared.
W/R/T your cylinder heads, make sure you have them resurfaced before reassembly as they are certainly warped after 305K.
If you do not have your headset, I have them for $205 delivered, includes bolts and O-ring for heater feed pipe.
1 - 3 of 3 Posts
