1 - 7 of 7 Posts
Polish and proud of it.
Yeah I'm looking to get some junk yard 15" rims and mode then at work ( mashine shop ) to fit the bolt patern on my Disco II .
Now What is the offset on the stock rims ?
Casue this rims will be -6 mm
I found that stock MIGHT be +40mm offset . Thus making the center of the rim move out by 46mm ( not full 2" ) . But since the rim is 7" it will make it only stick out 33mm from the original rims .
But That's if the stock rim is +40mm.
Can I get some help here ?
OH and will the aftermarket 15" will clear the rottor ?
Thanks Art
Former LR tech, Albany NY
fifteen is pushing it. YOu get mud and stuff your gonna have a problem.
And modifying the bolt pattern could cause the wheels to stretch.
Ok sorry , but I kind off don't get your responce .
Mud and stuff? where the rottor is ?
and rim to stretch ? They sell that rim in that bolt patern but it's -19 offset ( so it's more out ) . BTW that rim's face is practycly flat . But $30 per rim I don't mind .
actually, there have been Discos running 15" wheels for years. I think 15" was standard on the 3 door commercial Disco.
Get proper wheels though- bodging a junkyard wheel by redrilling it is hack.
Safarigard supposedly sells 15" steels with the 5 on 120mm lug pattern.. I don't see them on their site, but I know someone who ordered them... they haven't arrived yet though.
Discussion Starter · #6 ·
Well I found out what the off-set is on those rims . :(
It's 57mm and the rim is 8" wide.
So those -6mm 7" wide will posibly stick out more or less 2" . Thats to much . I will tare up the fenders on the stock lift .
1 - 7 of 7 Posts
