Ive done this to my 95 RRC. I used a 95 D1 Lt230. You'll also need the entire D1 shifter, rear transfer case mount, and a D1 front drive shaft. If you do this on a 94 and below, there might be issues with the parking brake assembly (the 95 RRC already has the D1 style brake drum, so its no problem). Otherwise it bolts inBadger1 said:Funrover you can find any LT230 Tcase from a D1 or 87-88RRC and swap out for the viscous unit. Between my 89 with the viscous tcase and my D1, I think there is quite a bit of difference between the two and the CDL is much better IMO.
sven said:Ive done this to my 95 RRC. I used a 95 D1 Lt230. You'll also need the entire D1 shifter, rear transfer case mount, and a D1 front drive shaft. If you do this on a 94 and below, there might be issues with the parking brake assembly (the 95 RRC already has the D1 style brake drum, so its no problem). Otherwise it bolts in![]()
Right.....But 95's are the same as a Disco1 (the older RRC's use a different style of parking brake linkage) So if you reuse the parking brake assembly from a 94 and lower RRC, you have to fab up a bracket for the parking brake linkage to make it work. Not exactly hard, but not exactly bolt-on.Badger1 said:All RRC's have that hand brake drum right behind the tcase! :drink1:
Thanks for the info... never knew that about the linkagesven said:Right.....But 95's are the same as a Disco1 (the older RRC's use a different style of parking brake linkage) So if you reuse the parking brake assembly from a 94 and lower RRC, you have to fab up a bracket for the parking brake linkage to make it work. Not exactly hard, but not exactly bolt-on.
