Well...another problem with my '95 4.0
I purchased the car last week. Test drove it and found no issues, aside from the front turn signal not working. I drove it home for 3 hours and after filling up on fuel the check engine light came on. No biggy I thought...I try registering the car (California) and AAA tells me I need to smog it even though it was smogged back in October of 2004. So now I knew that I would have a problem since a check engine light is an automatic failure.
I rush out and buy a OBDII reader and hook it up. Sure enough, 3 fault codes. Manufacturer Ignition system, misfire cyl 3, misfire general. I clear all three and the light goes out. I drive around and nothing changes. I then head down to my local AAA smog station. They run the test and it passes emissions, but fails the test due to computer not performing some test (not clear which one) and the check engine light came back on.
I got home and plugged in the reader and sure enough the ignition system error code comes up. I clear it a second time and after about 10 miles, the check engine light comes up.
I'm still trying to get my head around this and figure out whether this is a single issue going on, or a combination of things. It seems that one of the tests is with the fuel cap...Interestingly, my fault occured while playing with the cap. So I inspect my fuel cap and the thing comes apart in pieces in my hand?!? apparently its made of about 5 or 6 pieces.
So what is going on here?? yesterday I posted a problem with my right turn signal and foglamp not working. It seemed that the BeCM might be the culprit...now this....
sorry for the LONG story, but I wanted to give plenty of details and order since it might make the difference in diagnosing the problem.
So does anyone have any insight into what might be causing this and what I should check into first?
Thanks,
Tom
Thanks,
Tom
