1 - 2 of 2 Posts
Using a pair of pliers (grip the bit you twist with your fingers, grip it tight so pliers do not slip and mark the knob)to pull of the three knobs you will then see two screws remove screws panel will pull off revealing bulb.
Lynall
1 - 2 of 2 Posts
