1 - 7 of 7 Posts
member
Discussion Starter #1
I checked and they are O2 sensors codes. Are they up stream? Before cats.? Also what do they mean when together? This was after a long steep hill.
Thanks,
Dave
Rover-Holic and Admin
I hate to say this but if it is running normally I would probably let it be for a couple days. Than clear the codes and see if they come back. With everything the truck has gone through including sea level change it might just be a glitch
member
Discussion Starter #3
Thanks Army! was thinking same thing. I will clear the codes in the morning and drive and see if they come back. It has been driving fine.
Dave
if it pops back up I would check the connections. Make sure they are full seated and free of corrosion. I want to say that code is for upstream sensors.
member
Discussion Starter #5
Hi Army.
So just returned back from PR, had the Drag link and Track rod replaced due to worn out bushings. Did not get a chance to do the water pump yet.
But these two codes P0153 & P0134 retuned from last November when I had it shipped there. I cleared them then, and they did not come back. I drove it a couple of times as I fly there every 2 months or so. Now 8 months later they are back. I got them back the same day I arrived (2 1/2 months of it being parked this time). I cleared them and 80 miles or so they came back. The truck is driving fine though.
Are these 2 codes just for the driver side 02 front sensor, or for both Drivers and Passenger side front sensors? I did see some oil on the front passenger side one, could that be it? Wondering? Should I purchase 2 new front sensors and take them back with me in November when I return? Or clean the bit of oil I saw on the passenger front one?
I also purchased a battery tender to keep the battery from dying since this time I won't return back till mid November.
The battery seems to have hold 2 1/2 months parked, but did not want to take a risk to leave it 3 1/2 months.
Thanks,
Dave
Oil in the connection could cause a problem.
Off the top of my head I don’t remember if it was one side or both
member
Discussion Starter #7
I will get some electrical cleaner and spray the connections and then re install the 02 plug and see, but I will still take the sensors just in case. I have to get the truck emissions inspected there in Nov, it past it last year when I had it registered there.
The LR3's never give us any issues.
Dave
1 - 7 of 7 Posts
