Thanks for the advise.
I Will probably replace the Coil.... Not so easy to reach on my rig....
Thanks for the advise.A company called Extinct Motorsports is making the kit again. You can unplug the original coil packs (they're hard to reach) and abandon them in place if you get new coil packs. If you don't want to replace the coil packs, you'll need to remove your intake manifold to remove and relocate the old ones. Some say that you can remove them without taking off the manifold, but I think it'd be a real struggle.
Yes it is.Is that a G4?
I'll check.When reaching the coils in that position, I STRONGLY recommend disconnecting the brake servo vac pipe and the crankcase breather tube from the upper intake. You may otherwise break the vac pipe and/or the breather fitting if you roll a bit to your left. Been there; done that.
Would help if I read your tag.Yes it is.
From usa....
