Maybe the cold is just a coincidence, but on my 95 4.0SE the engine does two strange things: 1.) Every time you shut the car off there is an audible whistling sound which sounds like a WWII bomb dropping or a fan winding down. The sound only sounds for like 2 seconds and then stops (The amount of time between when the key is turned off and the engine actually stops turning. 2.) When the car is running if the RPM's drop to like below 750 then the engine will emit a constant squealing / whining sound which immediately goes away by bringing the RPM's up by 100 or more. This squealing / whining is only intermittent, it does not happen constantly. The car runs fine, I have had the squealing problem of the Classic alternator before, but this doesn't seem the same. This is something that "just started" about 1 month ago.
Any ideas? I know its not the engine, can the auto belt tensioner come loose?
