1 - 14 of 14 Posts
Discussion Starter #1
Ticky tick tick coming from the electrical fan.
It almost sounds like it?s lightly touching the bracket - ticky tick tick. But I know that?s highly unlikely.
Please confirm, the fan is dying. Correct?
Thanks.
Discussion Starter #2
To be more thorough, how can I test the electrical fan motor to verify?
Electrical has never been my strong-suit.
Super Moderator
First thing I would want to check is foreign material stuck in the fan (leaves, candy bar wrapper etc.)
Maybe pull the grille to take a really close look, spin it by hand, figure out where/what is making the noise. Also check for any " notchyness ir looseness " in the fan when you turn it by hand.
You could likely power it on manually by jumping fuse block relay terminals.
Sierrafery could likely tell you exactly what terminals if /when he is around.
Yes first of all do what @redtruck12 said then when you are certain that the blades are free remove relay R4 and bridge the perpendicular terminals with paperclip or something and the fan will run, no ignition required
though be aware thjat if it starts without aircon on it means that your engine is running too hot(with gauge in the moiddle) or the ECT sensor makes tricks cos the electric fan is there (beside A/C) to help engine cooling when the ECT input to the ECM gets to 212 °F
All you have to do to start the fans is turn the ignition on and switch the air-con on. There is no need to be pulling relays or any of that stuff.
Super Moderator
I think ambient temperature comes into play for the booster fan/condenser fan to engage although I don't recall the temp.
Maybe not an issue in Aus. Where it's almost always really hot.
it depends... the fan should start only if the ambient temperature input is 28*C(82 °F) or more on aircon request not always
Super Moderator
That's what I thought too.
I think 82f would be considered a brisk day down under����
Discussion Starter #9
Thanks all.
With the AC on, turning the ignition key to position 2 does start that fan running.
(And you?re right, the fan will/should run even w the AC off, if ambient temp, engine temp, and driving speed conditions are met).
In any event, there are no leaves or candy bar wrappers in the fan.
When the fan runs by itself (before starting the engine) The fan turns fine, freely, and no noise.
The ticky tick tick seems to be intermittant.
At the risk of being prejudice in favor of my own theory, doesn?t this further support the idea that the fan electric motor is on its way to die?
Discussion Starter #10
Ok, now I need to re-read the RAVE because fan not running this morning, despite turning on the AC.
It was 60F outside, but still I though the front electrical fan ran 100% of the time that the AC was on.
Hmmmm...
Discussion Starter #11
I was mistaken about the electric fan running all the time that the AC is on.
Engine cooling fan control
While the A/C system is on, operation of the electric engine cooling fan, to assist refrigerant condenser operation, is
determined by a combination of vehicle speed and external air temperature. When cooling fan operation is required,
the ATC ECU outputs a cooling fan request to the ECM, which then energises the cooling fan relay. The cooling fan
request is output if vehicle speed is 80 km/h or less while the external air temperature is 28 °C (82 °F) or more. The
request is cancelled, and the cooling fan switched off, if either the vehicle speed increases to 100 km/h, or the external
air temperature decreases to 25 °C (77 °F).
Of course I'll check it again this afternoon when it's 80F outside.
Cheers.
Your last 3 posts are the evidence that you missed my post nr #7 IMO or you ignored it cos it could have saved you to dig yourself as it has an attachemnt too :serious
Discussion Starter #13
Yes, Fery I did miss that - looks like I missed a whole batch of posts from you and Red, etc.
That's my oversight.
In any event, I'll try it again this afternoon with it 82F+ outside.
And, as always, really appreciate all you guys and this forum.
Stay tuned.
Discussion Starter #14
You guys were right ( of course ).
Fan running this afternoon.
No sounds.
I?ll close this one out.
Hopefully it wont get resurrected.
1 - 14 of 14 Posts
