Desperately need help!
Today I decided to flush out and replace the coolant in my 2006 lr3. After opening the bottom radiator hose, I let the coolant all drain out. I poured a ton of water into the reservoir and let it drain through. I reclamped the radiator hose and continued to fill the truck with 50/50 dexcool through the reservoir. Left cap off, bleeder valve loose, and started truck. Turned on heat.
Shortly after, the coolant began rapidly expanding. My reader showed coolant was reaching 240F and temp gauge on truck went above 3 oclock position. I shut it off to prevent overheat damage. Ive let it cool and tried several times, putting cap back on, draining more coolant, squeezing the coolant hoses, taking cap back off, all to no avail.
I am baffled and although i just drained coolant from the bottom twice until the reservoir was in normal range, im now looking at a filled to the brim reservoir once again. Thanks.
UPDATE
I screwed on resevoir cap and started it for the 100000th time. Rather than bubbling up, it actually lowered, and the engine stayed cool. I ran the heaters on full blast for a good ten minutes and the coolant stayed around 200F. Shut off the truck and topped of coolant to cold fill line. Ran beautifully 5 miles back to my house.
When we left for dinner, boom it overheats within 2 mins. Pulled over immediately with temp gauge peaking around 75% mark. Shut everything down and waited 15 mins. Coolant again had expanded to the cap. Coolant temp was 226. I opened the resevoir and it lowered back to the fill line.
Started the truck to attempt to make it a quarter mile back to the house. Everything was beautiful. When we arrived I drove around our community for 20 mins with no issue. Seriously WTF!! Im afraid to take this truck anywhere... Anyone have any ideas on whats happening and what I can do to get peace of mind? Im seriously regretting changing my coolant!!
UPDATE
