1 - 1 of 1 Posts
Hello, on an 03 Disco should the hose from the expansion tank to the throttle body be steel with rubber ends? My hose is all rubber stiff and cracked. I am thinking factory is steel. Let me know as I am looking to replace it. Is it common for the hose end on the expansion tank to leak as well? This started out as a plug replacement..... My pre-heater connection was leaking all over plug 3. The actually nipple on the pre-heater was very corroded and needed to be replaced. Good suggestion Mike....
1 - 1 of 1 Posts
