I have read practically every post on coolant loss and misfire and I am baffled by my own experience.
2002 D2, about 175,000 miles. Vehicle history:
- Replaced head gaskets two years ago; resurfaced and pressure tested heads. Replaced all spark plugs, wires, coil packs. It ran fine for over a year.
- Massive leak of coolant into sump last year; overhauled all engine front end components with new, including: timing cover, chain, sprockets, oil pump, water pump, thermostat.
Recent history: Slow coolant leak over past four months accompanied by misfire at start up for about 60 seconds - always showing cylinder #4 misfire. Replaced coolant reservoir bottle, cap, embrittled tubes from throttle body and from radiator top to reservoir.
Coolant leak stabilized to about one quart every 300 miles. Misfire consistent; practically every day showing cylinder #4 misfire...clear it, it comes back next day.
My diagnostics have included the following:
- Interchanged #4 and #6 spark plugs - misfire stayed with #4
- monitored engine oil - no sign of coolant in sump
- no sign of smoking in exhaust
- no coolant drips on garage floor
- engine is dry - looked especially for coolant leak at water pump and found none.
- no smell of coolant around vehicle
- pressure tested all cylinders:
#1 167.0
#3 161.0
#5 163.0
#7 164.0
#2 168.5
#4 179.0
#6 156.0
#8 160.6
The outlier is #4 , which makes me think that there is moisture in #4 , possibly coolant, giving better seal at piston rings and a higher cylinder pressure reading. I cannot imagine how coolant is getting into #4 , since it is an inside cylinder and far from the coolant passages feeding the heads from the block.
I am wracking my brains but can't come up with a definitive direction for what to do next. The machine is running superbly, very smooth and powerful after the first 60 seconds with rough running at startup.
Any opinions?
#1 167.0
#3 161.0
#5 163.0
#7 164.0
#2 168.5
#4 179.0
#6 156.0
#8 160.6
Any opinions?
