Another crank-no start issue...
I've done a bunch of searching regarding a no start problem but have a question regarding the symptoms and the behaviour of the crank position sensor. I have little to no spark (slight spark at first that seems to fade). Not a fueling issue. I have the factory service manual and it states that a bad crank position sensor will result in no tach reading. I can monitor the RPMs while cranking and the ECU is showing 145RPM or so.
If the sensor is bad, would I be able to read RPM? Also, the CEL turns off while cranking after one or two revolutions. I think I read that this is a symptom?
Background info:
1999 LR Discovery II 4.0 210k miles that belongs to a friend. Developed an intermittent miss a month or so ago which got progressively worse. Had codes for multi and cyls1,4&7 misfire. Same codes came back after clearing. Would go back and forth between running perfect one day, stalling the next. Since 1,4&7 are all on one coil pack I had him order one. I installed it yesterday, cleared the codes and it ran perfect all the way back to his house (5 miles or so). He later went out to start it and it fired, stumbled and then stalled. No codes stored. No fire on carb cleaner.
I pulled the intake again to make sure I didn't pinch anything (all good). I held my hand over one intake port and I can feel good vacuum. Pulled battery connection, armed disarmed alarm (plus lock/unlock door 4x).
Background info:
