2004 Disco, auto tranny.
It stopped working around the time I started having problems with the gear selector switch (code P0705). I pulled and cleaned the selector switch and it works fine now but I still have no cruise control. Not sure if the two are related or if it was a coincidence.
There are no check engine light codes
There are no vacuum lines from brake pedal. The unit is electrical.
The vacuum line between the actuator and the pump is good
The vacuum pump assembly holds vacuum
All my fuses are good
All my brake lights are good
My brake pedal switch is good
My gear selector switch is good
My cruise control master dash switch lights up
Horn works
What now?
Horn works
What now?
