Cruise Control 94/95MY ("soft dash" version)
This is my first post here. I bought a "soft dash" Classic a year ago with only 125K (kms) and from day one the cruise ENGAGE (Set+) worked when it felt like it. Knowing little about these cars (and not much more now!) the LR dealer snipped the end off the vac. hose (it was perished) and on e'bay I bought a new vac. pump but never did get around to installing it. Now it gets INTERESTING....
One day, in anger/frustration I pressed the top Set+ button (for ENGAGE/SET+) being the top button just to the right of the centre steering wheel air bag "hub" and the button fell off in protest.. which THEN left the small circuit board BARE and EXPOSED protruding from the RHS of the air bag "pad". I panicked, but upon feeling behind the board, I located what felt like a little "detent" button. When I pushed that "button" (gently THIS time!) TOWARD me with my forefinger, the cruise control was found to engage (Set) each and EVERY time. No exceptions!!
So AFTER all THAT.. it was the switch, because upon examination of the displaced (my "fault"!) "Set+" button, I found that its top plastic "pivot" point was broken whilst the lower one was about to go also. The top button had NEVER felt "right" (like the lower Resume- button did and IT had always worked) and was apparently trying to "twist" on its axis thereby preventing its inside "face" from depressing the "detent" set button on the rear of the circuit board.
I fitted a used switch (Set+/ Resume- etc as COMBINED in ONE "assembly") that I bought on E'bay and all was well.
Now I CRUISE all the time!
