1 - 7 of 7 Posts
Wheeler
Does anyone know the speed threshhold for ABS on the Disco II (probably same for P38)? ie: The min. speed at which the ABS operates and below which ABS is not engaged.
The only real time I've ever felt ABS on my DII is when I'm going down a hill (on paved ground) at like 5mph and hit a little bump, then it takes over and almost makes me crash....
SCSL said:
Does anyone know the speed threshhold for ABS on the Disco II (probably same for P38)? ie: The min. speed at which the ABS operates and below which ABS is not engaged.[/QUOTE
SCSL..i'm pretty sure it's right around 5 miles an hour. The light ck routine that is common with rovers i.e. (start engine..a.b.s. light is lit...drive away..reach 5 miles an hour..light goes out). This light check routine is exactly that..the e.c.u. is waiting to see road speed from the speed sensors...and at least 5 miles an hour must be reached for the sensors to read correctly....anything below that...no a.b.s.
Polish and proud of it.
I can look in the Service manual that I just recived couple days ago .
That thing is biger then a Bible .
1 - 7 of 7 Posts
