In my 95 LWB I have 75/140 Mobil 1 gear lube in Front & Rear final drives, as well as the transfer case, and she LOVES it (major improvements). However, last week, the parts counter at Flatirons Rover in Boulder, Co. told me to hold off on putting in the same fluid (75/140) in my swivel pin housings, because Rover had introduced some grease in tubes that didn't leak out, etc. Like an idiot, I decided to wait until they got some more in, and, of course, made a trip from Denver to Grand Junction only to hear that dreaded "clicking sound" when I got off the highway. I immediately drained both housings to confirm my suspicion that they were indeed almost totally empty. I added .8 quart of gear oil to both, and buttoned her back up. The clicking noise is still there, only not nearly as bad as before :shifty: . All I can assume at this point is that I did indeed "toast" the Driver's side CV, but it looks (sounds rather) like I caught the passenger side just in time.
My question: if I keep them well lubricated, how far can I drive with this clicking CV Joint WITHOUT causing additional damage? Can I go 400 miles back to Denver? Also, as I do all my own work, I intend to do the CV myself. Are there any tech-tips anyone can offer on this project and any guidance about a great place to by the CV Joint, seals, and special hub-nut tools, etc? Lastly, I am guessing that I should do BOTH sides at roughly the same time, just to be safe. Thank you so much for any assistance! Denver Dan :wave:
