My D2 has a slipped liner and a lot of off road kit... Question is, how much of it can be used on a D1?
OME full suspension lift. I know rear springs will swap. Fronts need the D2 seats which can swap. Shocks the front turrets are different and can be swapped?
ARB bull bar? I've seen this a few times. Other than the wheel opening being larger on a D2 and the wings being slightly wider it should bolt right on.
SD rack, section it shorter is a direct fit.
front great basin rovers double cardon drive shaft.. can this be used?
Rokstar fabrication sliders... hmmm not sure about this one being easy.
full south down skid plates... everything, front axle guard, steering guard, fuel tank, rear axle.... this won't fit a D1 completely different chassis and axles but probably a P38.
I know things like dash boards, wiper switches, window regulators are all swappable... a lot is actually.... but a lot isn't... anyone know first hand before i try this other stuff?
