Status
Not open for further replies.
1 - 2 of 2 Posts
Discussion Starter #1
Note: The following is a list of service intervals that the dealership maintains, more frequent maintenance on any of the items is never a bad idea.
7500 Service​
Exterior
Add 16 oz Land Rover Fuel Conditioner (LRN5010)
Inspect wiper blades
Under Vehicle
*Change engine oil and replace filter
Inspect tire pressures, condition and tread depth
Inspect brake pads, calipers and discs
Inspect trailer hitch attachment bolts for tightness
Change front and rear axle oil
Record performance of Service in Passport to Service
15000 Service​
Exterior
Lubricate door locks, check straps
Lubricate hood latch and safety catch, fuel door hinges
Interior
Check parking brake (Adjust if necessary)
Check seat belts
Under Hood
Inspect coolant hoses
Inspect radiator and AC condenser
Check power steering fluid level/ACE fluid level
Clean battery and terminals
Inspect serpentine drive belt
Check brake fluid level
Under Vehicle
Perform body corrosion warranty inspection
Inspect exhaust system and heat shields
Inspect brake lines
Lubricate drive shafts and U-joints
Inspect steering rods, joints and dust covers
Inspect shock absorbers
Inspect suspension links and mountings
Inspect wheel speed sensor and height sensor wiring
Inspect fuel and hydraulic lines
22500 Service​
Exterior
Under Vehicle
30000 Service
Exterior
Replace Alarm handset batteries
Interior
Check seat belts
Under Hood
Change brake fluid
*Replace air-cleaner element
Change engine coolant
Under Vehicle
Inspect brake lines
Change transfer gearbox oil
Change transmission fluid
Replace transmission fluid filter
Check front and rear axle oil level
37500 Service​
Exterior
Under Vehicle
45000 Service​
Exterior
Interior
Check seat belts
Under Hood
Replace serpentine drive belt
Under Vehicle
Inspect brake lines
Inspect engine and transmission mounts
52500 Service​
Exterior
Under Vehicle
60000 Service​
Exterior
Interior
Check seat belts
Under Hood
Change brake fluid
*Replace spark plugs
Under Vehicle
Inspect brake lines
Service SLS filter (if equipped)
1 - 2 of 2 Posts
Status
