I have an 05 Lr3 that I purchased a little less than a year ago.
When I bought it I knew that the front bearings needed to be replaced. I went to perform the task the other week and while backing out of the drive I hear a mechanical scrubbing sound and the amber HDC and brake lights appear on the console. The vehicle would not shift out of 2nd gear as well.
Figured it may have something to do with the bearings, pulled them off and replaced both sides, problem still occurs.
I noticed the lights will not illuminate until I turn the wheel sharp left, even with the engine off and car in park.
I replaced the brake switch, driver side wheel speed sensor, inspected brake lights, fixed corroded brake switch splice, new battery.
Any advice on what to check next?
****EDIT****
I believe I have narrowed it down to the steering column sensor.
Looks like there was a leak at some point as the steering column has some surface rust.
Thanks in advance.
****EDIT****
Thanks in advance.
