1 - 3 of 3 Posts
1993 range rover lwb - Roman Bronze
Discussion Starter #1
Is it possible to fit these defender110 rims onto a range rover classic. I have a pic of someone that did it, but he told me that the size he has are 18 inches....but im not rying to do that.....im trying to go 16 in....i rather go wider than the standard 205 height...... any response will greatly be appreciated.
The first pic is of the tire and the second pic is of the rover with a brooklands kit and those rims on them
ps..........by the way.....with my previous post of the Mechanic in georgia I have decided to have them replace the busted hose, correct the electrical problem and they should leave the tire wobble problem alone..........
You can fit the D110 rim on your classic.
They both have the same bolt pattern. The D110 rim is a 16inch rim, correct?
Don't confuse bolt pattern with tire diam.
1 - 3 of 3 Posts
