1 - 2 of 2 Posts
Discussion Starter #1
Good evening to all.
I want to upgrade my 110 DEFENDER 300 TDI 1997 MY 65 Amp Alternator with an 100 Amp Alternator from the Discovery 300 TDI.
Is YLE10113G is appropriate for this?
Is it necessary something additional to be done in order to mount it or does it fit to the original manifacturers mounting points of the 300 TDI engine as my original alternator?
Except for the 2 Defender headlights H4 - 60/55W I have also 4 additional headlights H3 - 55W.
Will I be able with this 100 Amp alternator to use simultaneously (on the same time) all 6 headlights together with taillights, sidelights, heater fan, radiator cooler fan, rear end door heated glass and will the alternator be able to supply enough current to all of them for a long time while driving?
Which brand YLE10113G is better in terms of quality, durability and reliability - HELLA or DENSO ?
What is your experience with both brands?
Every answer is welcomed.
Denso is the way to go and the YLE10113 is straight fit, calculate and do not exceed 1200W at once
1 - 2 of 2 Posts
