Disco Mike said:
80/90 wt is what is recommended all though I use 140 wt. in both diffs and the t/case. Royal Purple is good as is Mobil One are great. You might consider the synthetics over the regular dino oils, they do hold up better.
How about all your other fluids, have you done your brake and power steering fluids yet, many people forget them.
Mike J.
Disco Mike, just want to confirm you have a disco II?
Why do you use 140 wt? Would it be appropriate for use in my rover......my concern would be moving the oil when it is 19 deg F outside.....we have long and cold winters around these parts. Any pros, cons you could tell me.
Also for cellulararrest;
http://royalpurple.com/techa/faqsa.html#mo1a
Is Royal Purple® synthetic motor oil?
Yes. Royal Purple® Motor oils are composed of a proprietary formulation of synthetic base oils and synthetic additives containing iso-paraffinic diluents. "
The more I hear about royal puple, bias and not, I think its the real deal.
I havent changed my power steering and brake fluid......the last time that could have been changed was about 6k miles ago when I brought it in for a checkup.....my next checkup is comming soon...
Also, how often should I replace my engine oil? Ive been doing it probably way too often, but around every 2500 miles....using Castrol Syntec. Last time I changed it was about August.....and have put on around 1500 miles so far. That time around I used a K&N oversized oil filter for mine too. Does it need to be changed in the next 1k miles/ couple months???
btw, all oils are going to be full-synthetic...non of that cheap crap is going into the rover....I know it wont like it and sooner or later it will be regurgitating parts.
also, thx for help disco mike; I just got off my warrentee and feel that everything (fluids, spark wires, plugs?) needs to be replaced so I can set a "timer" and know when to replace it next.
