Hi, Marcus, New here. I have a Defender Td5, can I engage the diff lock while on the move, without pushing the clutch? Is there a maximum speed for doing this??
you can engage the diff lock whilst moving, but all wheels must be moving at the same speed, and that should be about 5 MPH.... and you need to push in the clutch.... so clutch > CDL to neutral > CDL to lock or any other position > release clutch and move forward...... -A
Engaging clutch has no bearing on using the CDL. Changing from hi-range to lo-range transfer gearing is only to be done at 5mph or less, or stopped with the trans in neutral. (Unless you own a new Range Rover) As far as I knew, the CDL may be engaged at "any" speed. of course do not engage CDL when on dry conditions unless you plan on traveling in a straight line. Changing to low is actually better to do between 2-5mph than stoppped. Less wear.
1 - 6 of 6 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
