1 - 7 of 7 Posts
Wheeler
I have both front & rear sway bars out of an '01 DII (soil sprung).
Not sure what problems, if any, you may encounter with taking the rear sway out on an SLS-equipped vehicle. You may want to give a call to an indie shop for advice on that. If you are wheeling to the point where you want to remove the sway bar, I would suggest swapping out the SLS for coils.
I don't think it's a good idea as the extra articulation may unseat the air bags besides, the DII will provide enough articulation for most heavy duty trails, without having to remove the sway bar.
Forward!
Discussion Starter · #6 ·
Thanks Disco, I thought about last night at work and decided to leave it alone. The airbags and compressor have already been replaced once(warranty) and I think they might start asking questions if it goes so soon after the fix. Coil spring conversion time for the D2 I think, as its purpose in life is beginning to change! LOL!
Thanks for the replys!!
Wheeler
DII is without a doubt a great performer. But when you're talking heavy duty trails, you stand to gain a lot by removing the sway bars. (your point about the airbags unseating is well taken). With ETC as the traction driver on a DII, and possibly CDL, keeping the tires on the ground is key. You can't articulate to the extent you need to w/ the sway bars attached. Plus, the sway bars do the opposite for you off-road as they do on-road. Just as they prevent body-roll on-road,,,they create body roll off-road because they lean the rig into the articulation, rather than allow the axle to drop out to the full extent the suspension will allow.
Obviously, the value-added depends on the trail. But on heavy duty obstacles or very deep mogul runs, a DII w/ sway bars attached is going to lead hard into the obstacle & risk rolling more so than one with sway bars removed.
1 - 7 of 7 Posts
