WHAT HE SAID IS THE EXACT FIX, IF THIS DOES NOT FIX IT YOU NEED A NEW TAIL DOOR LATCH, PART NUMBER MXC2008, GOOD LUCK WITH FIXING IT, LUBRICATING IT SHOULD WORK FOR SURE.browng5 said:If you remove the green oval LandRover badge, you get better access to spray to handle mechanism with WD40 or similar. Usually on sticks in the winter due to all the salt on the roads
