Have some random spare parts that I've collected over the last couple years. Everything's in good shape, some are even new. Links to eBay auctions are provided below, please get in touch with me via PM if you have any questions.
Still have a ton of other parts I haven't listed yet - feel free to let me know what you need.
D2 Rear Left window regulator (no motor) $15
1999 2004 Land Rover Discovery Left Rear Window Regulator | eBay
D2 Front Left (Driver) window regulator & motor $60
Land Rover Discovery 2 Front Left Driver Window Motor Regulator | eBay
D2/P38 SAI Solenoid $20
Land Rover Discovery 2 Range Rover P38 Secondary Air Injection Solenoid | eBay
D2/P38 SAI Valve $40 (each)
Land Rover Discovery 2 Range Rover P38 Secondary Air Injection Valve | eBay
D2/P38 SAI Pipe (attaches to head) $100
Land Rover Discovery 2 Range Rover P38 Secondary Air Injection Pipe | eBay
D2/P38 SAI Vacuum Lines $25
Land Rover Discovery 2 Range Rover P38 Secondary Air Injection Vacuum Lines | eBay
D2/P38 SAI Air Pipe $60
Land Rover Discovery 2 Secondary Air Injection Hard Air Pipe | eBay
D2/P38 SAI Pipe Fitting $20 (each)
Land Rover Discovery 2 Range Rover P38 Secondary Air Injection Pipe Fitting | eBay
D2 Wheel Studs $6 (each)
Land Rover Discovery 2 Wheel Hub Stud | eBay
D2 Exhaust Gaskets, Studs, & Nuts $50 (6 gaskets, 6 studs, 6 nuts - full set)
Land Rover Discovery 2 Exhaust Manifold Studs Nuts Gaskets Full Set | eBay
D2 Passenger Exhaust Manifold $55 (Studs removed)
Land Rover Discovery 2 Right Passenger Exhaust Manifold Studs Removed | eBay
