They are different, but I'm not sure of the dimensions. Bumpers and brush guards are not interchangeable between the D1 and D2 so I can't imagine the plow will just bolt up.
thats not good... i wonder how they differ if it is a slight differance ware i can cut and reweld the mount to work or not even close.....if some one had pix that would be great..They are different, but I'm not sure of the dimensions. Bumpers and brush guards are not interchangeable between the D1 and D2 so I can't imagine the plow will just bolt up.
I just bolted a DI bumper to my DII. All I had to do was trim about an inch off of the bottom of the grille. The frame horn dimensions are the same from DI to DII.They are different, but I'm not sure of the dimensions. Bumpers and brush guards are not interchangeable between the D1 and D2 so I can't imagine the plow will just bolt up.
That is a mount for my GoPro camera.What is that on the hood in between the the lr?
I wasent planing any suspension changes this year the plow is a light weight plow it weighs 380 lbs ...compair to a fisher at 780....i plan on mounting the plow then if i need heaver springs i will consider a 2" lift i will build the frame to ajust for the lift...What do you plan on doing with your old factory suspension? If you have not installed a HD lift your front end will be very low with the weight of the plow.
I thought it was a mount for the MACK bulldog :lol:
no time to do a lift before the snow fliesLol you might as well order that lift now.....save yourself the headaches
