1 - 5 of 5 Posts
Discussion Starter #1
2004 Facelift (Manual)
Engine wont turn over,everything seems dead
Put key in ignition and wont start not cranking, all that happens is i get 6 like audible alarm pings
My key fob has not worked for years i just open manually, noticed this time all the other doors don't unlock.
Alarm LED on dash not lit or flashing
Thought it might of been battery so charged it up and still the same.
Red LED flashing on Navigation System goes of when turn key
Is there any fuses for ECU,I have nanocam so if there is anything that I could check (limited use on this)T
Things that don't work
Windows
Indicators
Seats
Sun Roofs
Central Locking
Things that work
Horn
Blower
Wipers
Lights
lighter
Any help appreciated
Taza
very disco
There’s the main fuse/relay box under the hood which feeds the secondary fuse box under the steering wheel. Definitely check your fuses...
my fuse box (under the steering wheel) randomly gave up a month or two ago.
Any DTCs?
very disco
Unless the starter action is being interrupted electronically.
Check the voltage of the small wire on the starter solenoid when the key is turned to crank. It should be 12v.
1 - 5 of 5 Posts
