1 - 11 of 11 Posts
Hello,
I have acquired a 2000 Disco II with 128K miles on it. When I got it the Service engine light was on - and after checking the codes I found it had 8 codes all having to do with the oxygen sensors.
Replaced all 4 sensors and I am still getting 3 codes. p0140, p0141, and p0161.
I have checked several times to make sure they were all installed correctly and can't figure out what the problem is. I clear the codes and not even 10 miles later the service light comes back on.
I have been tinkering with cars since my first VW but the Disco II is very different creature and I really don't want to make things worse so any help will be greatly appreciated.
Thanks in advance,
Veedub3
· Premium Member
Did you clean and use die electric in the 02 connections?
· Premium Member
Do you have a good scanner so you can read the actual signals from the 0'2 to determine what is wrong?
· Premium Member
But, can your scanner actually watch the 02 sensors signals?
1 - 11 of 11 Posts
