"Maybe it should have one"
It is very common to find some recent models of automoviles that doesn't have fuel filter (in gasoline engines)
You will find as well, lots of people that will say "It should have one".
Well, I'm one of that guys.
I own a repair shop, and i've performed fuel filters adaptations several times on many japs and euro models.
The conversion is very simple, cheap, and normally will not compromise the good performance of the system.
I recomend it to my costumers 'cause of the bad quality of the fuel delivery in my community.
You simply have to find a good quality filter with a properly size and delivery rate, also, it is very important to check that it will support the pressure rate of the fuel system, so u will need some factory info.
Normally I use Nissan VG30 engine type fuel filter in big size engines. (Sorry don't have serial # right now) Anyway, it can't be very difficult to find a good application for your car, I have never made the conv' in LR, but i'm pretty sure that will be as simple as any oter modern car.
You will need a good craftsman, because he will have to plan the ubication, and improvise with common sence and knowledge.
Some cheap hardware and hoses will be enough for a safe and fuctional conversion.
Hope will be helpfull.
Cheers. :buttrock:
