Hello rover people
I have a 2000 Disco II that is not starting. I have read a lot of other posts that are very similar to mine. I just could not find a solid answer for what fixed it. So please give some advice.
The Disco ran very well with no codes or any other issues. A few weeks ago, the last time I drove it, it was good. I went to the mountians stayed a while, when I started it to go home it fired up and stalled. Then started fine and I went home with no issues. I had a few start and stops with no problem. A few weeks later (yesterday) it would not start.
20k on complete top end rebuild including camshaft lifters heads ect...
Starter turns just fine but will not fire up
Battery is charged
I just installed a new Bosch crank sensor today
It has spark
I tried a different fuel pump relay
I pulled the pump and bench tested it, seems to run fine
Tested power at the pump and it does Not prime with the ignition on, it seems to have power while the starter is spinning but the pump does not spin
The fuel cutoff switch was not triggered, I will try to bypass tomorrow
Any other ideas?
Battery is charged
It has spark
Any other ideas?
