2001 disco2. 112k miles.
After sitting for a few hours the disco will keep unlocking itself as though the unlock/disarm button on the fob is being pressed. All interior lights come on, exterior lights flash, and doors attempt to unlock. Disco will continue to unlock itself repeatedly until battery is dead, if left to sit that long. I say attempt because 3/5 door lock actuators are toast. Bad ones are front pass and drivers and rear drivers side.
Things I've done so far (one at a time)...battery from fob removed.
RF receiver in headliner disconnected.
All door lock actuators disconnected. (one at a time, then altogether)
Pass compartment fuse box removed and checked for damage/corrosion.
Checked central door lock switch.
Checked all fuses, relays.
Removed fuses for IDM, removed relays for flashers, fuse for central door lock and still I get a click at pass compartment fuse box when disco is trying to unlock/disarm...
NO aftermarket alarm is installed.
So any suggestions??
