Discovery 2 2001 wipers stop half way though
2195 Views 4 Replies 4 Participants Last post by  Racer X
My wipers are stopping half way on intermittent and then goes on but keeps stopping. There is a clicking every time it starts again.
1 - 5 of 5 Posts
Most likely the wiper motor assembly. If it were stopping electronically then it could be the wiper switch or the park switch inside the wiper motor.
Mine did the same thing, most likely the park switch. I replaced the wiper assembly wth one off eBay. You will need to pull the hood off to remove the plastic cowl piece.
Should i just replace the whole wiper motor?
No, you won't. If you take your time, you can remove the cowl without removing the hood.
Yes. If you can't find one on eBay, get in touch with Paul Grant.
1 - 5 of 5 Posts
