1 - 2 of 2 Posts
my disco 2 has started making a strange ticking noise when first started up on investigation if was found to the ace block underneath below drivers seat,when i remove fuse controling said unit the noise stops any ideas on replacing cost for this unit and how had is it to do..noise is contsant when corning
thanks martin :mad:
Is the clicking sound constant or does ir stop after a few seconds? My ECU unit for the ACE went bad on mine and it was opening the valve every few seconds. I think the new ECU was around $800. I don't know the price for the valve block it you have to replace it. I am sure it won't be cheap.
1 - 2 of 2 Posts
