Regarding my 2000 Disco's Harmon Kardon system:
I'm gutting the head unit, amp and CD changer in favor of a Pioneer AVIC 910BT nav/bells/whistles unit and a new Amplifier.
If I read my Rave wiring diagrams correctly, I see that the Harmon Kardon Amp is really an 8 channel amp (below is the left side - double it for the right):
1 - Left-Front Door-midrange-A-pillar-tweeter assembly (speakers are in series)
2 - Left-Front Door-lowrange woofer at bottom of door
3 - Left-Rear Door-lowrange-midrange speaker assembly (speakers are in series).
4 - one of the 6.5" Rear tailgate Subwoofers.
My question is this - I'd like to not buy 8 channels of amp. Has anyone had issue just connecting the "left front output" from an aftermarket amp to all THREE speakers on the corresponding side? Wire numbers 1 and 2 together in the above example. I believe there is a small inline resistor between the A pillar tweeter and the midrange acting as a crossover, so I dont see much of a problem unless the speakers are some weird ohmage. They're 'rated' at 15 watts, so an aftermarket amp should drive them to their death.
Other option would be to feed the sub channel to both back door woofers AND both front door woofers. Comments? Concerns?
This install will be complete with custom cut dash insert, etc. The only thing I'm interested in reusing are the speakers and their respective harnesses. The sound really nice. I'll replace them when it comes to that, but for now I want to reuse the speakers and harnesses that came out of the old factory amp.
Am I just overcomplicating this?
Thanks!
tekbench.
Thanks!
tekbench.
