1 - 3 of 3 Posts
Discussion Starter #1
Greetings!
Does anyone know where I can get the purple O-rings for the ABS shuttle valves?
I bought the ABS shuttle valve seal kit from Falconworks:
The kit includes 2 black seals (one for each shuttle valve - see top left of photo)
BUT INSTEAD
the shuttle valves that came out of my Disco don't have the black seals but rather have 3 purple O-rings per valve (see bottom center of photo)
I'd like to replace the O-rings . . . where can I get them?
Thank you very much!
You removed the whole assy which is not necessary, you have to remove that plunger on the right side which comes out from the middle of that body with o-rings and there are those seals you bought... that's the moving part, the big assy with orings is fix so quite unlikely for the orings to leak
the o rings are not avilable as dedicated spares, if you want to replace them go by measurement and buy Viton orings, watch carefully the tutorial and you'll see what i mean https://landroverclubvi.weebly.com/abs-svs-seals.html
Discussion Starter #3
sierrafery
Thank you VERY MUCH for your response!
They were stuck together and came out as one. I didn't realize that at the time.
I followed your advice, took them apart and replaced the black seals.
I did not replace the O-rings.
in case this happens to anyone else, attached is a photo that I hope explains it all
Thanks again sierrafery!!!
1 - 3 of 3 Posts
