I recentlt bought a '95 Disco with 164K Miles and I have a few questions regarding my new vehicle.
1. When I park the truck hot and go run an errand or something it usually is reluctant to start when I return and if it does it runs roughly until I'm under way where is smooths out shortly there after. A mechanic friend said it might be the temp sensor on the intake manifold is faulty or has a bad connection. Connection seems OK. Is there a test for the sensor? (My manual is in the mail as I write).
Is there a aftermarket code reader available that I could use to help diagnose my hot starting problem or is there someone in the LA area that could help me out???
Does anyoner have any other suggestions?
2. There is a noticable amount of slop in the driveline and I was woundering if there was a way to adjust this out or if I just get to wait until some part of the driveline fails from wear and tear and then replace it. The tranny also clunks when I put it into reverse and my friend said this was to be expected considering the miles and said not to worry about it. Yes??? No????
Any and all sugggestions appriciated.
Did you know that Lucas is the name of Daffy Duck in Latin America
Thanks
Eric
[email protected]
'95 Disovery
'62 Sunbeam Alpine SerII
Thanks
Eric
[email protected]
'95 Disovery
