1 - 2 of 2 Posts
So my 1998 LE, no power to dome lights. I initially thought maybe I just needed to insert the key and turn the ignition on to reset the cancel mode, not the case. This particular car is a new addition so not sure how long the problem has been around. Ignition key lamp comes on with doors open and dims to off as the dome lights should after a few seconds of the doors closing...The dome above the visors, center roof and cargo area are all the same... will not come on with door open, will not turn on with switch, no power with multimeter at the front one. Closkc does not work either which makes me think fuse, but the fuses all appear to be good...Ideas? I could probably find it if I dig around alot, but hoping there is some common issues someone here has had experience with in this.
Thanks
Discussion Starter · #2 ·
forgot to subscribe...
1 - 2 of 2 Posts
