1 - 4 of 4 Posts
Discussion Starter #1
'91 RR Classic is having a mysterious locking issue. When I lock the drivers' door from the outside it reopens instantly. I mean lock-unlock. It acts just like it does if the door is open open and you try it. Same thing. I was able to find two NOS actuators from Europe and that didn't fix the issue. It started out only doing it when it was cold and gradually developed into a full time thing. Everything is just dandy when operated from the passenger side. I've unplugged the drivers' actuator and just lock it manually. Any ideas or suggestions would be appreciated.
very disco
Have you suspected the latch?
It sounds like the truck “thinks” the door is open
Discussion Starter #3
Is this a fairly common weak point of failure point? I have seen the latches are readily available and they're not expensive. I guess it's worth a shot...
very disco
Out of the million problems my RRC has, locks aren’t one. However, my RRS, LR3, and D2 have all had at least one latch assembly replaced for silly reasons like this.
1 - 4 of 4 Posts
