1 - 7 of 7 Posts
Banned
From that page, check out the forward and backward icons on that site, as there is a narrative and several other pics of the door coming apart. Good luck, Kieran :wave:
the locks are electric,
Spray wd40 in vast amounts in any hole you can find while operating the locks.
if you have the little red straw with the wd40 you can spray into the door from the inside door release.
this will normally work
Sean
not forgetting you can overheat the locks if you lock and unlock to quickly. If you do wait 5 and all will be ok
1 - 7 of 7 Posts
