1 - 4 of 4 Posts
When I set the temp to heat my 2005 LR3 the air blows cold air on the driver side but toasty warm on the passenger side. This condition applies to the defroster too which was a big problem last winter. Any ideas? Thank you. :frown
member
Check that the driver temp knob its on the hot side. Also press the Econ button make sure it lights up red for econ. Use ECON always in winter or when cold out.
Dave
Still cabin heating issue.
Dave
Happy New Year,
I had to wait for it to finally get cold to try your suggestion. Unfortunately I am still cool on the driver side and toasty on the passenger side. In addition to being cold on the drive side cool air is blown at the wind shield the wipers work much less efficiently on the driver side (if it snows the snow actually builds up). It looks like I will need to bring this for service but I would like an idea what it could be hoping to lessen the possibility of being taken advantage of. Any ideas what may be causing this? BTW the AC works fine. Thank you again.
member
Hi Look,
I would have to look at it to tell you.
I live in Greenpoint, send me a pm and I can check it for you,
Dave
1 - 4 of 4 Posts
