1 - 5 of 5 Posts
Discussion Starter #1
Hey guys I think I outdid myself
earlier today I tightened my door handle on my drivers door as per
OkieRover.com
it was working great! Opened the door from the outside a couple times...hopped inside and opened the door a couple of times
Called it good, locked the doors and walked away
...came back out to it and couldn't open the door, went inside from the passenger side and still could not open the door
How can I get my door open so I can adjust it back?
Make certain the door is unlocking all the way. You'll have to manually lift the locking tab. I had the same problem after making some adjustments. Had to go back in a make a few more adjustments to get it right.
Mine did exactly the same thing after I tightened it. I'll apologize in advance for not knowing all the technical terms for all of the parts in the door, but here goes:
You will need a flashlight and a metal coat hanger.
You'll have to roll the window all the way down, then move the interior rubber edge by gently pulling toward the interior of the vehicle and out of the way. Once you can see down in the door frame from the top, use your flashlight to look down toward the back of the vehicle.
When you move the door handle, look in the door and see where the motion stops. There is a metal piece that is supposed to be lifted when the handle is pulled, but the part it lifts will have slipped under it. Essentially you need to bend and work your coat hanger down under that and pull up. The door will open immediately.
I'm attaching a photo, but the area is so tight I had trouble getting a good one. Keep in mind, once you have it open, this will not fix the problem. This will allow you to open the door so that you can remove the panel and loosen what you tightened with Oki's fix. I got over zealous with my tightening and the same thing happened to me. Getting the door open is the hard part, but while it took me hours to figure it out, hopefully this will give you a good starting point.
Discussion Starter #4
Awesome thanks fellas!
I was able to get it open by removing the door lock holder and pulling real hard upward on door lock and the door handle from the inside at the same time
Got the panel off and loosened that adjuster...now we're good!!!
Thanks for the help, I was frustrated there for a second...almost killed my "feel good about myself" mood
Cheers!
I'm not figuring out the trick here to pop this thing back open. Maybe I bent the main latch wrenching on the outside handle too hard, and the lock won't release until the pressure is off the main latch?
Here's a video of what's going on. I tried the coat hanger but had no luck. Video shows me pulling hard on the lock/unlock latch and then trying the inner door handle. You can tell the door handle is not doing a thing... I tried pulling up on the tab shown in the photo above... got a good solid pull on it but it was already as unlocked as it was going to get. Any ideas??
1 - 5 of 5 Posts
