1 - 3 of 3 Posts
Hi, is there a way to bypass the auto down feature of my driverside window? Most of the time it wont go up or down but on occassion it will so I know the motor and window work just thinking the Auto down feature may be causing issues. Other ideas welcome. Thanks!
Administrator
If it intermittently works up and down , sounds like a bad switch to me
Any unusual sounds when it does not work?
As a test you could swap switches and see how that changes things
I do hear a click once in awhile when I hit the down button, sounds like it's coming from the glove box. I did swap the switches and the passenger side window works fine. But switching the plug in to the passenger switch didn't make a change on the drivers window.
1 - 3 of 3 Posts
