1 - 4 of 4 Posts
If it reacts to the fob give two consecutive unlock commands cos it seems it's stuck in superlock mode, if the fob doesnt work fix this first or you'll have to brake the mechanism from inside
every other door will unlock and lock with the key also when i put it in drive none of the locks lock now
how do i break the mechanism from inside i have pulled door panel and can see the unit just not sure what to do from here
Can you hear any activity in that latch when you lock/unlock with the fob? if not see where the loom enters the door cos it might be chaffed there and the motors dont get feed... i dont know how exactly to brake that mechanism if that's the case, when mine failed it was removed by a mechanic
1 - 4 of 4 Posts
