1 - 2 of 2 Posts
Anyone know if the LR4 has grease points on the driveshaft? I'm hearing this slow squeak/squeal when moving slowly through a parking lot, it's not the brakes but appears to be coming from the middle underneath of the vehicle - any thoughts?
No, it is probably the center drive shaft carrier bearing. Check and see if it has slung grease at any of the joints as well. Unless you try and have it rebuilt if the bearing is bad, you will probably end up replacing the drive shaft.
1 - 2 of 2 Posts
