1 - 5 of 5 Posts
How do I get the cover off the driving light that's in the bumper? The passenger side bulb is not working and it looks like a sealed housing. Do I have to remove the entire assembly to get to the bulb?
Joe
96 D1 SE7
94 Volvo 850
Stuttgart, Germany
MG
Joe,
If you mean the lights on your rear fender (and your '96 is like my '95), you can gain access to the bulb from underneath the car, just lay on your back underneath the fender and you'll be able to follow the cables to the fitting. Then rotate, remove and replace.
Now if I only could find the correct light bulbs...
Cheers,
The light is in the front bumper in the lower portion under the headlights.
Tried to attach the pic but I'm not sure if it took.
Joe
96 D1 SE7
94 Volvo 850
Stuttgart, Germany
Joe
96 D1 SE7
94 Volvo 850
Stuttgart, Germany
Those are fog lights. Look behind under the valence (thats the dam). You will have to get busy with a screwdriver. Major pain.
Most don't like them and change them to driving/fog lights. Still have to change those bulbs, though.
Discussion Starter · #5 ·
That's what I thought when I looked at it but was trying to avoid. I'll get to it next week sometime. I have an appt with the dealership this week to get the remote programmed.
1 - 5 of 5 Posts
